Hello everyone! I stumbled across this site a few hours ago now and I was wondering how I am able to create a very simple application (.exe) that allows for a drop down selection to be pressed, then some text that corresponds to that selection be outputted next to it. That is all I would like to do! Thank you in advance!
Hi there, you cannot create .exe applications with Bubble. Bubble builds web applications that exist on the internet and are accessed through a browser.
It might be possible to use something like electron to wrap your Bubble web app as an .exe, but you’ll still need to be connected to the internet in order to use it.
Here an automation tools with .exe compiler easy to use.
