Need help with Parsing JSON text into a Bubble Data Structure
Hi Everyone, I’m trying to setup a backend workflow as described in this post. I’ve got Endpoint 1 detecting the payload from the webhook. My question is what action do I use to send the data from Endpoint 1 to Endpoint 2? The post mentions setting up a call using the API connector, however I’m not clear on how to do this. Looking forward to your tips and suggestions.
Manage to get this working. If you are stuck on the same problem, this is how I managed to solve it.
  1. Setup both Endpoints.
  2. Setup a call (post) to the URL of Endpoint 2 using the API connector. Make sure to include Content-Type = application/json in the header.
  3. Tigger the above API call within Endpoint 1 workflow.
4.After initializing Endpoint 2, you will be able to use any part of the JSON from the payload as a thing in bubble.
How do you initialize the call? Can you provide more details? My payload is a list of json.
The first workflow is a webhook and responds when it receives a payload. The first workflow triggers the second workflow. Hope that clarifies things.
trying to implement this, I believe I have it all correct. But, I need my payload to be the gpt response. Where is the payload defined besides in the Body of the api connector call? Thank you
