i need to calculate this pricing:
if the user input value is less then or equals to 10000 then another box will show “User Input0.10"
if the user input value is from 10001 to 50000 then another box will show "User Input0.08”
if the user input value is from 50001 to 100000 then another box will show “User Input0.06"
if the user input value is from 100001 or above then another box will show "User Input0.04”
i have tried this, but it’s not working:
Hi fellow Bubbler. Is this what are you looking for?
Thanks a lot edward, this worked and solved the problem!!
So i have another problem comes up, see this screenshot:
so when a user select
10000 from drop down the Total Price Box Should Show 1500
50000 from drop down the Total Price Box Should Show 6000
100000 from drop down the Total Price Box Should Show 10000
200000 from drop down the Total Price Box Should Show $16000
please help me to solve this
Just change the workflow I provided to When dropdown value is 10,000 Data Records etc. You would need to type in the exact value at the end of the argument
