🗺️New Plugin Release: Mapbox Maps for Bubble Mobile
Hi @janssen,
I’m sorry to hear that the project was scrapped.
Thank you for taking the time to report the issues you found in version 1.13.0. Even without the extra details, your feedback helps us keep an eye on potential regressions in our updates.
If you decide to start a new project or pick this one back up in the future, we’ll be here to help.
Best regards,
Support Team
Browse all Zeroqode Plugins for Bubble
Banner_Last3
Hey, would it be possible to allow for the “Add list of markers” action to define color as text, not as a database field? When I want to have all markers in a defined color I need to add this field to database and populate with the same value. I think it should work the same way as “As single marker” action!
Hi @twkrk,
Thank you for your feedback and for reaching out.
I understand your point about wanting to define a static color as text for the entire list of markers in the “Add list of markers” action, rather than relying on a database field for each entry. Currently, the plugin is designed so that when passing a list, the color is pulled from the data source to allow for dynamic coloring of individual markers based on your database records.
We appreciate this suggestion as it highlights a valid use case for applying a uniform color across a list without extra database fields. I will pass this idea along to our development team to see if we can add a static text option for the color field in a future update for the “Add list of markers” action.
For now, as a workaround, you would indeed need to include that color value within your data source to apply it to the list.
Please let me know if you have any other questions or suggestions!
Best regards,
Support Team
Banner_Last3
Hi @twkrk,
I am glad to inform you that we have published an update for the Mapbox Maps for Bubble Mobile plugin, version 1.16.0.
In this update, we added a “Static color” field to the "Add list of markers" action.
You can now set a single color as text for the entire list of markers directly in the action without needing to add and populate a dedicated color field in your database.
To start using this feature, please update the plugin to version 1.16.0 inside your Bubble application editor.
You can also check our official documentation for details on plugin settings: https://docs.zeroqode.com/plugins/mapbox-maps-for-bubble-mobile
If you have any other questions or suggestions, please let us know.
Best regards,
Support Team
Banner_Last3
Hi @ZeroqodeSupport just checking in again on the ability for this plugin to track user’s location in the background. Is the expo-task-manager library supported by bubble yet?
Hi @greg18,
Currently, the expo-task-manager library is not built into Bubble mobile apps. Bubble allows adding it as an additional library, but there is no official support for background tasks yet, and we cannot confirm that background location tracking would work reliably.
Here are a couple of technical details our team highlighted about how Bubble currently works with background tasks:
  • No guarantee of background execution: Background tasks must be registered when the app starts, while Bubble plugin code runs inside elements and actions, and there is no documented way to run it at app startup. If the OS restarts the app in the background, tracking may not work reliably.
  • Native configuration is not confirmed: Bubble lets plugins add Android permissions, including foreground service permissions, but there has been no confirmation from Bubble on whether iOS background location mode can be enabled or whether the Android foreground service itself can be configured through Bubble.
Please feel free to reach us again when you need some help or assistance. It will be a pleasure to cooperate.
Best regards,
Banner_Last3
Thanks @ZeroqodeSupport for your reply.
@fede.bubble can you please elaborate? I would like to convert my web app to mobile, but only if it allows expo-location and expo-task-managerfor background location tracking, via standard circular geofences in Expo.
If these actions are not available today, are they on the mobile roadmap?
