This showcased website on bubble - https://outkarma.org/
How do I get the affect of running numbers where it shows “Total Funds Raised”
Any guidance will be super helpful
@vishaltaylor if the website has a API you can get the information that you want or you will extract the information from website.
Best
Anderson
It’s a plugin. Search the marketplace
Sounds good. I will try to find it
If it helps, @vishaltaylor, it might be this plugin… couldn’t hurt to give it a look.
Perfect!
