Hey everyone,
I just released PDFShift Pro, a Bubble plugin that lets you generate PDFs and images from URLs or raw HTML using PDFShift, directly inside Bubble workflows.
It’s built for apps that need clean document generation without wiring everything manually in the API Connector.
What it can do
- Convert public URLs to PDF
- Convert raw HTML to PDF
- Generate password-protected PDFs
- Add PDF restrictions like no print, no copy, and no modify
- Generate PNG, JPEG, and WEBP images from URLs
- Capture full-page screenshots
- Capture specific page elements with CSS selectors
- Set page format, margins, orientation, delay, zoom, and print CSS
- Add custom CSS and JavaScript before generation
- Add headers and footers
- Add PDF metadata
- Add watermarks
- Check PDFShift credit usage
Good use cases
- Invoices
- Receipts
- Contracts
- Reports
- Certificates
- Quotes
- Statements
- Order summaries
- Dashboard screenshots
- Printable pages
- Protected customer documents
- Image previews and web screenshots
Plugin Page:
Demo:
Editor:
I’d love any feedback, suggestions, or feature requests from the Bubble community.
