All metamask features must be used only inside the metamask browser (this is a thing with all web3 apps not only on bubble, when using metamask connector)
However, you can use Walletconnect and connect to your MetaMask directly from a mobile browser. You can do a test with walletconnect demo page
Hi I managed with the plugin to log in using metamask. Now I am trying to figure out how to get automatically all ERC-Token Balances and display it in a repeated group. F. e. a user has 10 different tokens and I want all of it to be displayed on the landing page using a repeated group. Is that somehow possible? I am struggling since days on that. On your demo its working with an individual contract using an input field. I dont wanna use it i want the plugin to check all Tokens of the user while loging in and display it.
I’m enjoying your plugin a lot. I’ve seen a while ago you had a question regarding the ABI extractor on Ethereum’s testnets. I am trying to work with a smart contract on Polygon, and more precisely on the Mumbai testnet, but the ABI extractor does not seem to work here (though the Read contract feature works perfectly once I’ve manually pasted the ABI). The “When Web3Utils ABI Ready” does not return any event.
Hi guys! I’ve come across this plug in and it looks amazing.
The app I’m building needs to work without metamask, and instead keep the private key of a user in the app and do things on his behalf.
Before I dive into the plugin I’d love to know if what I need can be accomplished with the plugin.
first thing is that this feature works only for verified contracts, and secondly is that the plugin doesn’t support Mumbai testnet.
We will add it in the next update but in the meantime, test on ethereum testnet like Rinkeby or Ropsten.
Hello,
Thanks for your fast reply, glad to hear this. I think the contract is verified and its ABI is public .
Thanks a lot for adding this to the next update. Also, is the plugin supporting Polygon main net at the moment?
I’ve created a staging mint website trying to figure everything with your awesome plugin out! When trying to mint a NFT from my staging website i get this error:
Hey there, on mobile you need to open the app inside the MetaMask integrated browser (this is how it works when using MetaMask on all web3 apps, not only bubble).
Another way to use it on mobile is visa WalletConnect plugin.
hello, where can I find the plug & minus for the minting? I’ve added a group box with a button for example but I do not see the plug & minus grouped in the elements on the side?
Hello i got the metamask plugin and im trying to set it up but im having issues with it. when i create a button and add a workflow to connect to web3 metamask, i dont see the metamask popup window that shows up at the right hand side of the screen. please what could be the cause?
