🦊 [Plugin] Web3 & MetaMask by NovaBloq
Update v.2.26.6
If you are using WRITE CONTRACT action, please read this.
Transaction Value parameter will now autoconvert to WEI , there is no need to manually convert it or use the To Wei action anymore. Just insert the number you need.
Make sure to make the changes and test it before going live.
Is this not compatible with Pulse Chain or am I not doing something correct. I cant seem to get the sign message for login to work without going back to ETH and using the change network pop up
friends, good afternoon,
Would it be possible for me to create a stake system with nft with the plugin? for example: I have nft X and I put it for Stake, with that the user can earn X token value.
It would be something like play to earn.
nft or simply put 1 token and after X time I can receive a higher token value.
Hi NovaBloq team, we are migrating applications. I bought the web3 & metamask plugin in the old version and want to use it in the new release. Can I do an uninstall and reinstall or do I need to repurchase it? Please advise. We are planning to launch this weekend. Appreciate your urgency.
This plugin can’t connect to a new network or a private network. Is anyone tried that already?
