Having a strange issue where when opening a popup it doesn’t automatically scroll to the top. I have added a “scroll to” element, but to no avail.
I had the issue then I used it as a reusable element and it worked perfectly fine. Though may be a bug if you previously had it scroll to the pop up.
NB.
For a reusable element pop up you need not to scroll to element.
Cheers!
Cheers for the idea, unfortunately no luck
Actually, on running it in Step by step mode, it works, but not in the full version, let me add a wait action.
Added it and that’s fixed it.
Thanks, @koechamos51
@cliffwoodjames can you use the workflow event “When a pop up is opened” inside the reusable element to scroll
