Possible to Place Repeating Groups Side by Side?
I’m trying to put two repeating groups side by side on a page - is that possible? Doesn’t want to let me do it (combined pixel total is under 1080 which is width of page). See screenshot - thanks for the help!
Parent group align to parent,take both repeating group inside of it
I’m assuming you’re using a responsive page format. If so, maybe the following would work.
Make a new group, alignment type of row.
Put your two RGs in there. They should automatically align left to right.
You may need to fiddle with the widths of them. Like maybe set both of them fixed at 50%.
I have personally never tried this before, but this is what I would try first if I wanted to do this.
