Hi everyone, maybe someone can help or give some hints.
I have a deployed model via Azure OpenAI based on GPT-4 with my settings. The model is working, if you deploy the web application, you can see that everything is working and also visible in chat playgroud. The problem is that if you use Azure OpenAI Service plugin with endpoint to the desired model - error 400. If you use the endpoint of the main model, from which you can deploy the others - everything works, but, I need mine. Microsoft assures me that everything should work and apparently the error is somewhere in Workflow or other things. Thanks in advance!
Why don’t you share your workflows here?
