Problem with dropdown lists in editor
Hey guys !!
I have a problem with the dropdown lists in the editor. When I hover on the item I wan’t to select this one changes continuously with the item above it. I makes it really hard and annoying to select.
These are the kind of dropdown lists I’m talking about.
I’ve already sent a message to Bubble but it remained unanswered.
I use Bubble on Chrome. I don’t know if it’s because I have the Hobby plan.
Thank you for your insights :slight_smile:
Might be worth trying to do the same in an incognito window. It could be that you have an extension interfering with Bubble.
Have you tried that already?
Ohh thank you !! It works fine now !
What kind of extensions do this ?
