Problem with Sequence of Actions in a workflow
I have series of actions to be processed in a sequence when I run a workflow.
In the below screenshot, I have 8 actions to be run in a sequential order as arranged in this workflow. The problem is … before Action #2 is completely processed, Action #3 is being run which is impacting rest of the actions.
In the above scenario, all the actions are dependent on the output of their previous actions.
Kindly Help
Did you try adding a pause before next action?
Thank you very much @skylershelton for letting me know this option.
I just tried to use this option but it shows it wont apply for the workflows that modify data.
Screen Shot 2017-02-08 at 10.21.41 AM
My Actions does modify the data in the bubble database.
Perhaps if you trigger a custom workflow, instead of keeping all the steps inside one? Would that work?
Perhaps including the break that @skylershelton mentioned before the workflow is run.
@emmanuel we past the day trying finding this problem… we patch it, but there’s something new today, that was not there yesterday? Same problem as @samuel describe. Was working fine last 3 months until yesterday 5hpm.
It was the same problem? Add List only adding last item
