Resposive Margin Problem
I’m new on Bubble platform. I want the mobile view of my site not to have gaps on the side. How can I do that?
Hi @tolgaunlu2001, welcome! :wave:
If your groups are not fixed (allowing Bubble to expand/contract them), then you can “collapse margins” on elements whenever their container is less than or equal to a certain width.
See this screenshot of a group in the responsive editor:
… compared to the same group without collapsing:
Play around with those settings and it should get you the results you’re looking for!
Cheers,
Gaby
Coaching No Code Apps
Join our Facebook group for insider access to no-code development
Get professional development services
Enroll in expert-led courses and products
Thanks a lot! I fixed my problem with your answer.
