Hi there!
I’m trying to run a code of javascript that needs to be placed right before the end of the body tag. The purpose of this tag is to redirect outbound links to an affiliate link. I tried putting the code in the HTML element but I’m not sure if that will trigger the javascript code or not. I also want the code to dynamically populate with a data field from the database, so the HTML editor seems to be what I want but I don’t think the code is running correctly. Is there a way to edit the body field and add this code just before the end of that tag?
