The plot thickens
I agree with that. Itâs for sure a risk - whether itâs worth it to secure the webhook isnât obvious.
For what itâs worth, Iâm currently sticking to the event + time check method with IP validation as I know that thereâs no way for clients to get an event ID in basically all of my apps + client apps.
It was formerly there and was removed during an update to our API documentation. However, we will be adding the capability of this url parameter back into our documentation, so you should be able to see it there soon.
Hi @georgecollier ,
Thanks for the detailed explanation! I do have a question though. Whatâs the âonly whenâ for âterminate this workflowâ look like?
I know I should terminate it if no event could be found, but how to craft that conditional, I donât know.
Would âresult of step 1âs body id :is emptyâ work?
You assistance would be greatly appreciated!
Only when result of step 1âs returned an error is no should do the trick (the âcheck event API call nerds headers and continue workflow checkboxes enabled in API connectorâ
Do you know whether or where this got published in the Bubble manual? I donât find it.
Great post! Thank you so much.
I tried this with LemonSqueezy and it seems to work just fine. Was wondering if there is anything LemonSqueezy specific to note?
I heard LemonSqueezy was built on top of stripe (not sure if true). Also, donât mean to hijack this thread. Can delete if you want to keep it to Stripe only.
Thanks either way!
Do you need to expose the endpoint to use the webhook as only a trigger? If I donât want to expose any endpoints at all, could I just refetch at certain intervals? Itâs concerning that Bubble only allows you to generate a single type of API token (full admin access to everything) rather than dynamically allowing only limited access.
if the endopoint is not publicly accessible stripe canât send requests to it. the solution is easy: donât use the admin token for stripe webhooks and use only the data that you fetch from stripe using the api connector.
Yep thatâs what I think Iâll do using recurring workflows. Thanks!
Just stumbled upon this thread. Nice summary, @georgecollier . It seems to reiterate the basic strategy I outlined several years ago (and which I still use).
Having said that, Iâll be implementing a ârelayâ approach (not unlike this Cloudflare example) in an upcoming project. I made that decision based on the anticipated higher volume, higher dollar amounts, and higher risk profile of the transactions.
Anyway, itâs a shame Bubble doesnât provide access to the raw request data (similar to the raw body text feature of API calls). It would make things simpler and easier. I like simple. ![]()
FYI, and sorry to bump an old thread, but I have created a Bubble feature request for a truly âRawâ body text for signature verification, as suggested by Bubble support. If we build support for this request it might expedite it. Or not, but one can only hope.
Hey @georgecollier ,
Iâm a bit late to the party, but this is the solution I came up with to deal with the problem. What are your thoughts on it? Does it work? Or should I add more stuff on top of it?
The final approach Iâd recommend is fetching the event from Stripe based on the input event ID.
- Check event using webhook event ID
- Use result of step 1 in any data
- Make sure you only do stuff after checking you havenât already processed this event ID (by storing any processed event IDs in the database)
Whatâs wrong with checking subscriptions instead? I used this approach since it might be possible that another event occurred on the same subscription?
I feel like getting data for the current status of the subscription would simply give me the latest results, no?
You can do that too I guess, but that only works for simple implementations. Other users will want to do stuff when subscriptions update, are created, are deleted, etc, and checking the event gives you a good foundation to do all of that.
Hey guys, on top of the other solutions in this thread - the only other mechanism that I can recommend in authorising webhooks (and this applies to other services) is using Basic Auth instead of giving up App API key.
So instead of yourapp.com/api/?api_token=xzbcmnxbmnbc You can use
randomtoken:randomtoken@yourapp.com/api/
Then on your endpoint, detect headers and check if auth matches.
Can you explain this further?
Hey @randomanon , select the âdetect headersâ on your API endpoint and then once initialized, it will have the headers:authorization value. Check that this is the value is consistent with what youâve provided e.g. https://randomtoken:randomtoken@yourapp.com/api/
randomtoken:randomtoken is the value you customize.
This can be used in conjunction with other checks in the thread.
I again urge you all to add your comments/upvotes to the feature I suggested, which would make webhook signing possible in the way itâs intended to work, signature verification.
