To give you some background. I got this website through a template. And there was initially another group in between the “all tools” and “plan & billing” groups.
Now when on the tool page, I’m unable to adjust the corner roundness to make it look like the tool is selected for the page - it works on the top but not on the bottom.
You can also find attached the image for the settings for the group above.
There are at least a couple ways to go about it, depending on how the element hierarchy is structured. The way I do it in one of my apps is via a conditional on the background shape or group inside the RG (assuming the sidebar nav uses a RG). Just set the Border roundness top-rightonly if it’s the last cell in the RG - i.e. the last nav item.
If you’d like more explicit instructions, please provide a screenshot of the relevant portion of the nav bar. If a RG is not used for the sidebar nav, the same basic concept applies. If you get stuck, feel free to PM me a view-only link to your editor.
Then it’s the gray background of the last nav item - likely a Text or Group element. (To send a PM, just click my avatar and then the “Message” button.)
