Hey Guys!
I am new to bubble and amazed by all the possibilities it offers. That’s great stuff so far! Thanks to the smart people behind this.
Currently, I am building an MVP for a price calculator. The first step is to calculate distances between a warehouse and multiple addresses. I’ve stored all addresses’ longitude and latitude data and use this data as the origin address. The destination address (warehouse) is typed in as a geographical address.
Problem: Using the built-in distance calculator takes too long (roughly 30 distance calculations) to calculate all distances which is why I tried to set up the Google Maps Distance Matrix API. I got the API call to work in Postman, however, if I try to set the API up in bubble and use dynamic values (the addresses’ longitude and latitude data) I fail.
Can someone tell me what I need to do?
That’s what the Call looks like - I want to trigger the distance calculation via a button and search for all addresses longitude/latitude data.
However, calculating the distance for our handling terminal in Atlanta (ATL) does not work as I can’t specify the dynamic inputs correctly:
Appreciate any input! Thanks a lot.
Best,
Julian
