[Solved] (HELP) Trigger a popup with a Header element
`Hi
I was wondering how a Header element could trigger a popup?
When i started editing my Header element and made an action like (Show element -> Popup) the popup doesnt show up in the list since the Header element is not binded to the pages
Are you editing the standard reusable header? If so, the popup must be part of the reusable element
it worked thanks!
