SQL Database Connector connection issues
If you specify the OFFSET parameter in the request, then the request works http://joxi.ru/v291dZEf4EllO2.
But if you change the OFFSET parameter to dynamic http://joxi.ru/VrwwWOLToBY3dr, then the request stops working and returns an error http://joxi.ru/82QapdgI8PvW72
Has anyone solved this problem?
You could give our plugin a try, we built it to solve issues we ran into with free connector: SQL Database Connector Pro Plugin | Bubble
Does your plugin support the OFFSET statement?
Yes. All valid SQL statements are supported. However I haven’t specifically tested offset. If you find there is an issue and it isn’t working properly, I can fix it right away for you.
The documentation is here if you want to look it over first: Introduction - SQL Database Connector Pro
I have read your documentation. I need to use OFFSET statement in Get data from external API. And from your documentation it follows that only the Action is available in your plugin.
Try using OFFSET $1 and not OFFSET ?
still an error
http://joxi.ru/ZrJ5OD1TQJzVPA
http://joxi.ru/YmEj1EOTGnz4E2
@emmanuel Can you make corrections to the plugin?
I think something might be wrong on your query somewhere. I just had a chance to test the OFFSET $1/number syntax as you have in your recent query and it worked with no problem (through their connector).
Did you do a test for MySQL? If not, try making a test for MySQL. It’s not just me that has this problem. Thanks to.
Variables $1 do not work for me in any request. Works requests only with variables?
I decided to not be lazy this morning and setup and test this syntax on a MySQL DB. You are correct that there is an issue with the offset variable.
Also as a note your original ? mark syntax is correct for MySql variable replacement, however when putting the variable in the offset it does incorrectly add quotes around the number which causes the error.
I know these Bubble errors can really hold up a project so I banged my head against the wall trying a number of different syntax formats to find a solution for you, none of which worked. Your best option is to email support and let them know you have a confirmed bug and ask them to make a fix.
Alternatively, if there is a way for your app to set a state variable rather than get data from API you could look into the plugin I mentioned (it is for reasons just like this one that we created it in the first place).
Sorry I can’t be of more help.
Thanks, you confirmed my guess. I already wrote to the support service, waiting for a response.
I’m posting a Bubble support response here. To not waste time in vain.
Thanks for circling back around on this for the benefit of others. That response really doesn’t make any sense to me, but as I previously mentioned, it’s for exactly that kind of reason that we built our plugin and made it available for others.
Did you find a solution? I’m currently having the same issue. I need to use dynamic offset for pagination. Thanks!
@borjaobeso1 The only solution that I am aware of is to use our paid plugin (linked above). The official Bubble response was that they don’t support the OFFSET statement.
plugin does not support dynamic offset. I enlisted the help of a programmer who wrote a SQL query handler. The SQL Database Connector plugin is not suitable for the work done, it has many limitations.
@wwweb2401 or use our plugin noted above which does support dynamic offset.
