I have a reusable sidebar element in my app however I can’t figure out how to make the sidebar sticky and not scroll when using the new responsive engine.
I have the sidebar element set to align to parent with a column sub-group within it.
The page it is being used on is set to row and I have set the vertical alignment of the reusable element to vertical stretch, but I still can’t get the menu bar to not scroll out of view.
Is anyone able to explain how they have fixed this issue?
Thanks @adamhholmes the link to the editor you provided was really useful and I now have it working without using reusable elements. (I had not thought of using both a floating group to hold the content and a normal group to keep the spacing).
However, I have not been able to make the “group side-bar-space”, floating group, and content in the floating group into one reusable element so it can be easily duplicated. Have you found a way to do this?
Hello. I don’t know if I can help you but in this case : Apex-dashboard | Bubble Editor you have an exemple of sidebar with HTML. Turn the menu group in reusable, not the white sidebar. Put the reusable menu on a white sidebar and give the ID : Sticky.
I hope to be clear and helpful.
