Hi guys!
I have a floating group on he right side of a page. I want the element to float till it reaches another element or a page position, then stop floating. Similar to the Airbnb Experience page ( https://www.airbnb.com/experiences/25414?&source=p1¤tTab=&searchId= ). Is this possible within Bubble?
Thanks in advance!
You can hack this by hiding the floating group when “current page scrolling position” is at a specific Y coordinate value and show a static group in the same position.
Gaby | Coaching Bubble
Hi Gaby,
Thanks! :)I just discovered that and have implemented this, so I’m halfway there. However, I have some elements that shrink/stretch, so the position would have to be dynamic. Is there a way to pull the current position of another element and reference this in the workflow?
You can use a Group Focus to hold the static stuff since that element uses a reference element for placement.
Thanks a bunch. I’ll give it a try and report back. Thanks
I was playing around with floating and group focus using sliders aswell, that made it possibe to travel up down left and right… pretty cool
Great idea with using the Group Focus. This kept my static element in place. i did however have to estimate the current page position (for hiding and unhiding the static element) as the other elements on the page stretch.
Thanks again
