I have a thing associated with each item in my element. When you click on it, I want to set the “last_selected_node” state field. My element is based on a Jquery plugin and has an event handler for clicking that looks like the code below. I have tried it both with a stored “thing” and with a new “thing” gotten from the databse APi (this latest version.) In either case when I call publishState with the “thing” object I get the exception below the code.
Help?
Code:
inst.on(“select_node.jstree”, function (e, data) {
console.log(“node selected”);
GetBubbleRecord(data.node.data.bubble_node_id,result => {
instance.publishState(‘last_selected_node’,result);
instance.triggerEvent(“item_selected”);
Exception:
Calling evaluate_property outside of an autorun or watcher
at e.evaluate_property (https://dhtiece9044ep.cloudfront.net/package/run_debug_js/5cdb5580cdfd657a3ccecc3977dd78141ae56c6385d278b54c4aea96fdb49973/xfalse/x9:18:112178)
at o (https://dhtiece9044ep.cloudfront.net/package/run_debug_js/5cdb5580cdfd657a3ccecc3977dd78141ae56c6385d278b54c4aea96fdb49973/xfalse/x9:18:474941)
at C (https://dhtiece9044ep.cloudfront.net/package/run_debug_js/5cdb5580cdfd657a3ccecc3977dd78141ae56c6385d278b54c4aea96fdb49973/xfalse/x9:18:475060)
at a (https://dhtiece9044ep.cloudfront.net/package/run_debug_js/5cdb5580cdfd657a3ccecc3977dd78141ae56c6385d278b54c4aea96fdb49973/xfalse/x9:18:477444)
at T (https://dhtiece9044ep.cloudfront.net/package/run_debug_js/5cdb5580cdfd657a3ccecc3977dd78141ae56c6385d278b54c4aea96fdb49973/xfalse/x9:18:466263)
at https://dhtiece9044ep.cloudfront.net/package/run_debug_js/5cdb5580cdfd657a3ccecc3977dd78141ae56c6385d278b54c4aea96fdb49973/xfalse/x9:18:477556
at e.state (https://dhtiece9044ep.cloudfront.net/package/run_debug_js/5cdb5580cdfd657a3ccecc3977dd78141ae56c6385d278b54c4aea96fdb49973/xfalse/x9:18:116203)
at https://dhtiece9044ep.cloudfront.net/package/run_debug_js/5cdb5580cdfd657a3ccecc3977dd78141ae56c6385d278b54c4aea96fdb49973/xfalse/x9:18:473043
at Object.M.t.publishState (https://dhtiece9044ep.cloudfront.net/package/run_debug_js/5cdb5580cdfd657a3ccecc3977dd78141ae56c6385d278b54c4aea96fdb49973/xfalse/x9:18:472938)
at eval (PLUGIN_TreeView–testing–initialize–TreeView-.js:48:23)
at Object.eval [as success] (PLUGIN_TreeView–testing–initialize–TreeView-.js:7:16)
at i (https://dhtiece9044ep.cloudfront.net/package/run_debug_js/5cdb5580cdfd657a3ccecc3977dd78141ae56c6385d278b54c4aea96fdb49973/xfalse/x9:2:27983)
at Object.fireWith [as resolveWith] (https://dhtiece9044ep.cloudfront.net/package/run_debug_js/5cdb5580cdfd657a3ccecc3977dd78141ae56c6385d278b54c4aea96fdb49973/xfalse/x9:2:28749)
at A (https://dhtiece9044ep.cloudfront.net/package/run_debug_js/5cdb5580cdfd657a3ccecc3977dd78141ae56c6385d278b54c4aea96fdb49973/xfalse/x9:4:14203)
at XMLHttpRequest. (https://dhtiece9044ep.cloudfront.net/package/run_debug_js/5cdb5580cdfd657a3ccecc3977dd78141ae56c6385d278b54c4aea96fdb49973/xfalse/x9:4:16491)
