We Need a CSS Grid System
We need a CSS grid system.
If Bubble just added Bootstrap’s UI, development would be a lot simpler.
After 10 years of using Bubble, I have arrived at the conclusion it is somewhat simpler to write code. Its just cleaner. You use a column of some width, and its automatically responsive.
I am tired of troubleshooting responsiveness in Bubble. It’s a massive time suck. Love the platform, but the UI leaves more structure to be desired.
Are you using the new responsive engine or you continue to build using the one engine? Because the new responsive engine is mostly using css flexbox with row and column…Not exactly the same thing as grid but a lot better vs old engine
I am using the new one.
