Why is this happening.
Editor
Editor 2
Preview
Inspector
Bubble is a blank canvas. Other tools give you a responsiveness structure. In Bubble you need to build the structure yourself.
Put elements within groups, manage the parent group width (example: set it to fixed width), preview.
Watch tutorials on managing responsiveness
Sorry - not sure I understand. Why is it that the Icon isn’t showing? I have made a Circular Link (text = icon) and it’s not showing. Why is this?
I’ve just gone and put the Text (dynamically pulling the Font Awesome string from the database) within a group within a repeating group and still face the same issue…
Try using normal text on the link and see what happens
It works just fine with normal text, it’s an issue with the FA
No issue. It is just that font awesome is covering the icon.
Sorry, I’m not clear?
@cmarchan - here is an example
Saw it from my iPad. At the moment I cannot recreate the issue.
Try using the dB instead of option sets
I can’t see it on Incognito or my iphone…
See here - on the inspector it says the element isn’t visible which is odd…
