Directly from site.
Unless you use external services that is meant to serve content faster (CDN services) and it has to have plugin with bubble if you are not going to build your own.
Services like
MS azure… uploadcare… AWS Amazon…
Usually with Wordpress site I often go with CDN like KeyCDN for faster site speed, so when i start using Bubble I was wondering if I can do the same with it.
Aren’t the images that are uploaded directly to the bubble D.B. actually being uploaded to AWS Amazon, after which our Bubble D.B. is just storing the AWS URL for that image?
Every time I upload an image, I see in the file manager the AWS URL representing the image URL…When I use a dynamic image in an image element I can enter that AWS URL directly and the image is displayed on page preview.
Is there a difference between using AWS Amazon as a separate storage which you would then need a plugin to link back to the Bubble site?
Yes right they are the same. But according to his question given he stated he is newbie (which he can not tell the difference between site and aws amazoon)
He asked site or google drive or normal storage services
I said site.
Or same storage like bubble in AWS amazon but little cheaper or other faster storage places.
