Zip Code on Stripe.js Please Help :(
Hi, I’m using Stripe.js specifically the stripe element everything is working fine when I’m testing the US - USD currrency
But when I want to test other country the zipcode input on the stripe element doesnt allow me to add that have zip codes with letters just numbers.
and since I am testing a country that has letters in its zip code . it is not working
any ideas on how to solve this? Thank you
When you double click on the stripe element the settings options box appears. Close to the top of that it has a section about the postcode. Set it to No. That will remove the ZIP code part. Im from the UK and had the same issue
You are right! Thank you very much!
