Hi Louisa,
I have tried to copy the settings of you dinosaurs’ Drag and Drop activity but I couldn’t find the option ‘matched’ in the Conditional settings of the Repeating Group of the draggable elements (corresponding to your draggable Dinosaurs). Could you please help me to sort this out? Please be aware that I have just started playing with .bubble and that I am an absolute beginner.
Many thanks
Francesco
Hi @francesco.rosa69 ,
'matched is a custom state on the drop area. Below is a screenshot and you can read about custom states in the Bubble reference or here in the forum. I also found a video that explains them.
I hope this helps.
Louis
Thanks so much for the drag and drop example. I’m trying to add drag/drop functionality to my bubble app that is Mobile Native but the issue is that as soon as you click on an item it starts dragging. This is a problem if the user is trying to scroll instead of drag.
Does anyone know of a way to add a “click and hold” feature to this so the user has to hold on a draggable element before they can start dragging it?
