Adapting workflows [please help!] I am stuck
Hello,
is there a way to change the workflow on a button and allow it to adapt depending on the number of input?
so for example I have 3 input on my app as a default but I want to make the input changeable to up to 10 inputs
so in my workflow in button, it will add steps according to the number of inputs?
Is that a possibility?
You can enable any number of workflows to a button. You can create several workflows with the starting event “an element is clicked” and conditions like “Only when the number of inputs is x”.
