Advance interface objects
Did you come up with any numbers?
So this would cover quite some cases :slight_smile:
Wow, i just was about to ask for this feature. I’ll check it out right now. Thank you!
@emmanuel Amazing! Why did I wake up and check my phone. Now I’m not going to be able to sleep. :wink:
@emmanuel now we just need the ability to drag n’ drop in between other items. Currently it looks like when you drag something it will only appear at the bottom. :wink:
It’s a different feature. But try to be creative and use the current cell’s index. You should be able to do what you’re tying to do… :wink:
Will it be possible to use this feature by dragging and dropping an item on the same repeating group?
I“ve tried with no success.
