Announcing Buildprint AI: Build on Bubble with Claude Code and Codex 🎉
Sure as soon as you can explain to me how an AI that doesn’t work got a 30% increase in user satisfaction and 2x greater user activation :slight_smile:
Truly mind-blowing that meaningless stats like that would be boosted in this day and age. Not sure how “satisfaction” can be quantified, yet alone down to a granularity of 30%. The study reeks of a New York grad-school-gender studies paper. Pretty sure qualitative analytics would be more meaningful i.e. “this sucks” or “this doesn’t suck.” And the 2x multiple of user activations is meaningless without numbers.
I’m scared of them acquiring Buildprint in the future. The feature gates are, UI, and release rate is going to drop like crazy.
@georgecollier - First of all, a great tool that you have built!! I believe our customers would find this as a very valuable AI assitant for the app.
I have setup the MCP server, and using the chatgpt for passing questions about the app (like how many invoices are pending to be paid, etc.) I see that it is calling the Agent and waiting for its status. But, at the same time, when I go to the Buildprint.ai chat interface, the query and the response are summarized there correctly. But it doesn’t seem to send that data over to chatgpt while using MCP server.
Is this any configuration issue on my side, or anything else. I would appreciate any assistance.
Thanks.
Buildprint can merge branches and resolve conflicts
Buildprint now has the ability to merge any Bubble branch, and resolve conflicts if they exist.
For web users, ensure Buildprint has permission to access both branches. This feature is available in new conversations.
For CLI users, update the Buildprint CLI to the latest version.
This is really useful for:
  • efficiently merging many branches
  • getting Buildprint to merge its own work
  • resolving conflicts more effectively and making post-merge changes to repair any lost work intuitively
Buildprint is not able to deploy to live.
Can I have one demo video please of how it helps to build and maintain bubble apps.
What are you looking for? Just try it out!
@georgecollier I’m struggling to setup Gemini on Buildprint. Following your instructions on the Gemini CLI I get the following error:
Accessing or displaying sensitive authentication credentials, such as those stored in oauth_creds.json, is strictly prohibited to ensure the security of your account."
Any suggestions?
Ask ChatGPT to help you get the token you need
Heads up from June 15th Claude will be nerfed thanks to Anthropic
OpenAI/ChatGPT subscription is the best value + highest quality way to use Buildprint!
If you want to use Claude while still using subscription limits from June 15th, you can always use the Buildprint CLI in the Claude Code UI on your computer.
Just started use “Tests”.
Great work. Loving it so far!
A few things that would make it even better:
  1. Folders for “Components” (currently, folders are only for “Tests”)
  2. For “Runs”, show total run time (at the moment it has (a) time run was started/created, and (b) time per step)
  3. You may want to update the documentation regarding the “one step per click” rule of thumb. Seems like the testing is a lot more powerful than that.
  4. Ability to copy and paste steps in bulk. I recently built a web component and I’m getting Claude Code to provide the test scenarios. It would be great to not have to copy and paste them one step at a time.
A few questions:
  1. The time it takes to complete a step seems quite inconsistent. In one run, a step might take 13s, and then in another run (same test, same step, same user) the step takes 6m57s. Got any ideas?
  2. Does Buildprint retain the context of previous runs? (i.e., if it runs the same test multiple times, should it get faster?)
  3. Are screenshots per step limited to x4? I had one step testing multiple options in a feature and it correctly tested all 7 options but only took x4 screenshots. Same when I tested it multiple times.
Anyone having issues syncing with a Bubble app and find a way around it? (it can only see one unnamed reusable no matter what i do)..?
You’ll need to DM me with your app ID and I can investigate, there will be some issue with the app JSON
Improved merges, better UI gen and search expression gen
A new Buildprint update is live, mostly focused on making app editing, branch merging, and generated files safer.
For CLI users, update with:
buildprint update
or:
npm install -g buildprint@latest
This release includes:
  • Better branch merge reliability, with clearer conflict guidance when Bubble cannot merge branches automatically
  • A new warning for fixed-width group containers, which commonly cause responsive/layout issues in Bubble apps
  • Better validation for database searches, especially preventing invalid advanced constraints from being used where Bubble only supports normal search constraints
  • Fixed CSV preview downloads so exported CSVs download from the full stored file, not the truncated inline preview in chat
  • Claude usage notice updates ahead of Anthropic’s June 15th changes for affected users
Buildprint still does not deploy to live. Branch merging is for safely combining Bubble branches and resolving conflicts, not pushing changes live automatically.
Inconsistent step run times imply the test would benefit from more specific instructions.
Buildprint doesn’t retain context from previous test runs though this is something we’ll add at some point - I just want to ensure it’s well implemented as a ‘self improving test’.
Screenshots / test artifacts are not limited so the limit to four is likely just coincidence and you can always provide more guidance about what screenshots/videos it should take.
Hey folks, small but useful Buildprint CLI release today: v0.1.13 is live.
Update with:
What’s new
Read Bubble data from the CLI
There are new buildprint data commands for reading Bubble database data directly through Buildprint:
buildprint data search
buildprint data fetch
buildprint data aggregate
This is mainly useful for debugging, agents, and automation. You can now search records, fetch specific records by unique ID, or run aggregate queries without jumping out of your local workflow even when MCP isn’t configured.
check and apply are less fussy
buildprint check warnings are now treated properly as non-blocking.
Previously, a check could pass with warnings, but buildprint apply or buildprint check --auto-apply could still refuse to continue. That should now behave as expected: errors block apply, warnings stay visible but do not stop the workflow.
Buildprint’s internal output is ignored correctly
The CLI writes some diagnostics and metadata into .buildprint/. That folder is now excluded from workspace validation and freshness checks, so Buildprint should no longer mistake its own generated files for Bubble app content.
This release also improves a few edges around quickstart/update messaging, redundant init handling, JSON check autofix reporting, and targeted workflow validation.
cooking
At this rate @georgecollier will make his own Bubble soon
AI slop!
