Announcing Buildprint AI: Build on Bubble with Claude Code and Codex 🎉
Buildprint is obviously awesome. Nobody cares “how” you made it, and it underlines the fact that people care about the results - not how something got built or what tech stack was used.
The question that’s always on the back of my mind however is, could buildprint have ever been made on bubble itself? I realise it’s not really bubbles forte in terms of what type of app it’s best suited for - but I also feel that inorder to survive this new age and compete with ai “code”, bubble has to be able to pretty much be capable of doing everything that someone could want to do…even something like buildprint.
In your opinion, based on building buildprintt, what would bubble have to provide & improve to make it a genuine appealing & competitive choice for building something like buildprint? What are the current major blockers etc :thinking:
It would have taken him a year longer and it would have been buggy and slow.
Actually not, the ‘weight’ of the second branch is different to the first as it has different nodes/layout hence the exact ‘formatted’ layout is a touch different
Not the MCP or CLI, but the logic that’s in there, probably. It would be too expensive for me to run, though and there would’ve been a fair amount of custom code around it.
Ah, nice touch
Tests that branch, self improve, and self-maintain
The tests feature has been significantly upgraded.
First, the test builder has been moved to a canvas, which supports branching and conditions.
During the test, the agent will complete all relevant branches (prioritising left to right for nodes with multiple branches - the steps are shown on each node so you know roughly which order it will execute).
Self improving tests
Tests are now self-improving. The test will get faster over future runs, as the agent builds knowledge of the most efficient way to complete the test and any gotchas.
Better test history view
You can now view test runs directly on a canvas, and see associated screenshots/videos directly alongside the relevant steps. This makes it easy to see the path the agent follows and investigate test failures.
Coming soon
We view tests as an important part of the development lifecycle for any serious app.
  • We’ll be supporting ‘tests as code’, so that Buildprint can implement tests alongside its work and maintain them as it updates the application. This saves the manual entry, and makes it easier to maintain tests for features that change.
  • We’ll make it even easier to set up test automations that run on a schedule, or on branch merge/deploy. This is already possible with the Automations feature, but we want to implement it in the test builder directly.
  • We’ll implement concurrency control so that test runs don’t fail for hitting your agent concurrency limit, and run when capacity becomes available on your workspace
Hi George, @georgecollier
First, I want to say thank you. BuildPrint has been a game changer for me.
I have been using BuildPrint intensively for the last 3 weeks on my iPad and Mac, and honestly my reaction is: how did I not start using this earlier? I am currently managing an emergency, so I’m using BuildPrint around 10 to 20 hours per day. My agent keeps getting better and better because it understands the context of what we’re fixing. I have already saved months of work in just a few weeks. According to BuildPrint stats, I’m close to 10,000 actions in less than a month. There is no going back for me :joy:
I have two requests:
  1. Conversation limit
I understand BuildPrint already allows around 1,000 conversations/interactions, but the count seems to include background activity that I don’t directly see. The counter my assistant shows me only reflects the visible interactive exchanges between me and the AI.
In real usage, the limit feels much smaller because BuildPrint counts many AI/background interactions. A normal troubleshooting session can easily create a 10x to 12x interaction factor compared to what I see as a “normal conversation.”
Often, I’m not doing something that requires huge AI power, but I need to stay in the same conversation because the AI fully understands the context. When I fork or restart a branch/conversation, I lose a lot of that working context, even if I attach a detailed document.
Would it be possible to either:
  • increase the practical limit for heavy users;
  • make the visible/user-facing counter match the real BuildPrint count better;
  • or provide a way to preserve context more reliably when starting a new conversation?
    next…
  1. Conversation counter on iPhone/iPad
On iPhone and iPad, the :warning: icon that shows the conversation count is not accessible. So when I’m working from mobile, I can’t see where I am in the real limit.
I never thought I would be at the gym and still working on Bubble with BuildPrint on my iPhone or iPad during jogging :joy: But that is now happening, and mobile visibility would really help.
Again, thank you for what you’re building. I’m honestly surprised there are not already thousands of Bubble builders moving to BuildPrint.
BuildPrint has already changed the way I work.
Thank you again,
John M. :flexed_biceps:
This has been released!
Yikes!
This limit includes tool uses. We don’t technically have to enforce the limit, but it leads to bad/confusing results because users do a long conversation, and the AI performance degrades over time.
For this reason, we soft-push users into forking the conversation. This preserves the conversation (compacted), any files created, and any draft changes that haven’t been pushed to Bubble yet. So, forking is pretty good now.
I’ll check that out.
Buildprint actually has over 1,000 Bubble apps connected!
That’s already a huge success! :tada: :flexed_biceps:
@georgecollier
I wanted to ask if you have ever seen this type of issue before.
I have one admin page that reacts strangely whenever I make changes through Bubble or BuildPrint. I assume there may be some weird code or behavior injected at some point by one of the AI agents :sweat_smile:
The issue is that I get kicked out of my admin page almost immediately and land on another page. It happens repeatedly, sometimes every 15 seconds or so, which makes it very painful to work because I constantly have to navigate back to the admin page.
What is strange is that no other page in the app behaves this way. It seems isolated to that admin page.
I already sent a bug report to Bubble a few days ago, but I was wondering if you have seen this particular type of behavior before in BuildPrint/Bubble workflows, and if yes, whether there is a known solution or something specific I should check.
Hopefully someone finds the cause before I’m forced to create an admin2 page :sweat_smile:
Thanks again,
Haven’t seen it, no
Tests are just users running the application, it’s unlikely to be related (unless through some configuration in your app logic, you’re logged into the same accounts as the test runners and there’s some redirect logic to prevent that happening
You were right — the issue is not resolved.
I thought stopping the two automation tests had fixed it, but it was only a coincidence. The admin page still redirects/kicks me out afterward.
Your explanation makes sense: if the test runners are simply users running the app, then the issue is probably not the tests themselves, unless my app logic is reacting to the same logged-in account/session or some redirect rule tied to that user.
So the problem is still active. I’ll keep looking into the admin page redirect logic, especially anything related to:
  • logged-in user state;
  • shared admin/test accounts;
  • Browser Storage;
  • User / UserM admin detection;
  • any redirect rule that could be triggered unexpectedly.
Thanks — your clarification helped narrow the direction.
Tests as code with Buildprint
Automated tests are now available as code with Buildprint.
If using the web version, try /test-builder and Buildprint will set up automatic tests for your application.
If using the CLI, update to the latest version, and Buildprint will be able to manage your application tests alongside the logic.
If Buildprint is working on a feature, you can instruct it to add new tests when done or update existing ones.
@georgecollier Aware of any ongoing issues? Got a review in “Viewed relationships” status now for around 20 minutes, and the last attempt failed. Using GPT 5.5.
Is your app large
Yes, very
Yeah I think I shipped a memory leak in the CLI that affects buildprint context which probably crashed the sandbox
well I didn’t ship it, codex shipped it
But fixing this evening probably
If you want to work around it, just install CLI and use in Codex/Claude Code/Cursor locally as we only allocate 4GB RAM for the sandboxes
The speed of features you’re shipping weekly is insane. This is the only thread that gets a new update every 2-3 days with something worth looking into. :clap::clap::clap: @georgecollier
@building4stripe this should be fixed now in new conversations (and update the CLI if you’re using it)
