Announcing Buildprint AI: Build on Bubble with Claude Code and Codex 🎉
Awesome, thanks!!
@georgecollier
George, I keep insisting that I still have absolutely no idea what the CLI really is… but honestly, what you’re building is becoming hard to “sell” because it saves me so much time :grinning_face_with_smiling_eyes:
I received your email yesterday and started digging into it a bit more. Yet another update that’s going to save me hours and hours of work. I simply wanted to say thank you.
For anyone looking to have an AI manager that can communicate with coding agents, I highly recommend the Codex (ChatGPT) + BuildPrint with CLI combination. It’s truly an incredible discovery. :flexed_biceps:
Thank you, @georgecollier, for making this available for free so everyone can use it and get more value. You’re a superhero for the Bubble community.
Which AI model do you guys like for troubleshooting?
I’ve been using ChatGPT 5.5 in low reasoning and I’m wondering if you guys have had success with other models.
Buildprint with Composer 2.5 and the latest CLI version is really quite fun.
Update: sorry for the noise — it seems to have resolved itself on its own. Ownership verification is now going through and Buildprint is connected to my app. Thanks!
We had some downtime due to one of our upstream provider (Railway)'s Google Cloud Platform accounts getting deleted. Kinda crazy! But all is resolved now.
Better mentions, improved repeating groups, /document
Mentions are now a lot more dynamic and easy to use. Use @ or / to tag branches, reviews, Linear issues, files, and skills.
Clipboard-20260520-123931-645
Improved repeating group support
Repeating groups are now better handled by Buildprint to reduce them being formatted incorrectly. This is active for new conversations. If using the CLI, make sure to update with buildprint update.
New /document skill
The /document skill will go through your codebase and document it in Bubble comments. Buildprint has first-class editor comments support and using comments helps you understand logic, as well as allowing Buildprint to ‘leave notes’ that it can see later, as it can easily see and update comments alongside its work.
@georgecollier It’s my 2nd day of using Buildprint.ai and it’s been amazing and very useful. Much thanks for making it available for free.
Has anyone here seen Buildprint create an issue in the issue checker?
We’re getting very close to ‘zero issues’ (I personally haven’t seen Buildprint create an issue in a few days).
If you do see one, you can help out the project by:
  1. Fixing the issue first
  2. Send the following prompt:
Resync the version. I’ve fixed an issue with XYZ . Please see what I did differently and explain why your approach was wrong. Include specific JSON context of the before, what you tried, and what the correct solution was. The more specific and detailed JSON context we have, the better we can repro, create test case, and fix if there’s a bug. Please write this to a Markdown bug report which will be sent to Buildprint to improve the Buildprint tools!
  1. DM me the response file
Additionally, if there’s additional things it regularly does which are technically valid but just dumb (e.g we recently fixed an issue that made it tend towards fixed row repeating groups incorrectly), then you can report those in the same way.
I have noticed two things:
  1. Doing a bulk update on a custom plugin action CSA, it was unable to fill in one of the fields, it filled but with “exprn_11” or something.
  2. I was using it to do responsive work and it started creating conditionals with properties that aren’t possible. For example, on <768px, it added a condition change on a bunch of Group elements of Container layout from Row to Column. Which obviously Bubble doesn’t support via the condition changes pane. I could even click in where it says Column and I get a Row, Column, Fixed, and Absolute options. Obviously nothing actually happens from it.
Also: what’s considered a big app for Buildprint? Any way to measure? Curious.
Created a skill to make sure Buildprint sticks to my design system. The skill references my group styles and when to use them, key reusable UI elements, etc. I spent 2-3 hours going back and forth to ensure the skill works.
The key here is to create a scratch page, let Buildprint build a UI using your skill and then push back on the chat when it does something wrong. Keep asking your agent to review and explain why it messed up or why it got it right.
Also, I made adjustments to the UI my agent built and then ask it to review my changes and explain why it was better.
Do that until you’re 100% happy.
At the end of that chat, create a new “master design skill.”
Last night, I went out for drinks and built an entire page from my phone.
Yep this is one approach, you can also use the “Project style” feature in the project settings for project specific guidance.
I think we should probably add more auto-onboarding stuff which detects the project’s design system and creates this stuff for you.
Hahhahha
Are you sure it didn’t do anything in run mode? I’m pretty sure this actually works and it’s just soft disabled.
App sizes over 100MB (from exporting your .bubble file from general settings) is a large app.
Though, it’s not 1:1, there are many simple apps that are very large because of tech debt / poor design…
Buildprint now works with the native changelog
Buildprint is now fully integrated with the native Bubble changelog in the version control tab.
This means you can easily see what changes it applied, and click on them to navigate to them. Previously, we would only create savepoints. Now, savepoints are still created, but you can also view more granular changes in the changelog.
Other fixes and improvements
  • Reusable element group data reference expression improvements
  • Fixed issue with schedule API workflow not selecting the correct workflow or date to schedule for
  • We now auto-select the provider you just connected as your default model if you previously used the Buildprint default
  • We now detect invalid Bubble app IDs at the point of signup, as lots of users get stuck and confused when the collaborator is not detected due to them entering an incorrect app ID
  • Buildprint can now give you a link to test which automatically logs you in on the right page/branch/user if you ask it to
@georgecollier Just thinking ahead here about the best way to keep using Buildprint. I know you mentioned in the past about Anthropic/Claude nerfing the integration, so I am guessing after June 15th we would have to use the Anthropic API cost structure if we still want to use it within Buildprint, correct?
I understand I can hookup Codex in BP to keep things as is, but lets say I want to keep using Anthropic’s subscription, what would you say is an optimal ‘stack’ moving forward for that?
I saw you mention Composer 2.5, which I am not familiar with, but I do regularly use claude code in VS code for other stuff. Is it a good option to connect to BP through VSC and how would it compare to using Buildprint normally, and how would it compare to Composer 2.5?
I understand there could be a lot here, it changes fast, and there is a lot of preference built in, but I am just considering a good ‘stack’ here so I don’t need to constantly rethink / rejig it and can get the most out of BP. Thanks!
The best option for users that don’t want to deal with a CLI/MCP/IDE/any other three letter acronym is Buildprint Web.
For anyone already running agents on their machine, doing agent driven development, the Buildprint CLI is best.
You can install it with npm install -g buildprint
Then, instruct your agent to setup the Buildprint CLI. It’ll handle stuff and also install the MCP server for you. You’ll just need to give it a token from the CLI tab in the Buildprint integrations page.
It is better because it runs on your system so feels faster, works with any agent, and generally just feels more responsive.
Composer 2.5 is a new model only available in Cursor and it’s mostly smart but very fast. It means you can be in the loop and stay focused on one task rather than having to monitor multiple agents at once to be productive.
Anyone here spending more time in Buildprint than in the Bubble editor?
Yes. For the past 3 weeks, I’ve mostly been doing only small touch-ups directly in Bubble.
I’d say I’m now around 80% AI / Buildprint and 20% Bubble editor, and honestly I’m very happy with that workflow.
For debugging and structured changes, it saves me a lot of time. I still go back to Bubble to validate visually and make small manual adjustments, but most of the thinking, inspection, and iteration now happens through AI/Buildprint.
