Have you tried putting them into folders, which let you organise them easily?
Have you tried opening a side chat?
Yes
âŚTrue : Iâm bad at managing folders, my keypoint is to make sure i donât loose my functional documentation that i try to contain in 1 conversation and still if you have 20 conversations in your folder, the 1 important is easily lost (itâs coming back to shared documentation between conversation)
Unless i miss something, side chat is not compatible with the buildprint iOS app (testflight)⌠so i admit iâve stopped using it
Thanks for coming to office hours everyone! Recording will be uploaded soon.
For anyone that wasnât there, if you want to be moved off the logs waitlist, upgrade to Bubbleâs Growth plan by end of the weekend and youâll be moved off the waitlist next week (if youâre already on Growth/Team/Enterprise etc then youâll be moved off waitlist too)
I missed it unfortunately! Looking forward to watching the recording please!
crazy
Buildprint is brilliant. Great job @georgecollier . Upgrading to Pro shortly
@georgecollier Could you add the ability to give the token a label so we know why it was created?
Feature request: I have two ChatGPT/Codex subscriptions. I would love to connect both, and just toggle once I hit my limit.
For now just disconnect and connect a new one
But $200/mo plan (even $100/mo) on Codex should be more than enough for all but the most active power users?
Big update time!
Tests in Buildprint were cool but kind of slow, expensive, and unreliable. All bad things for automated tests.
Testing has just been rebuilt from the ground up. For now, you can still view and run legacy tests in the UI, but will not be able to build new ones.
For now, weâve removed the ability to automatically run tests from Buildprint Web. Instead, you ask the agent to run tests for you. This lets an agent easily test its work after making changes.
Whilst tests run via CLI, you can monitor and debug them via web. Each test includes screenshots and a video recording of the end to end test.
Best practices are available here.
