Best way to build a newsletter system?
should i be using the normal bubble email sending workflow, or are there plugins much more fit for this?
Hey @trybizrep,
I think that you can input a Unsubscribe Group ID in the default “Send Email” in Bubble. However, I’m not sure how reliable it might be since Bubble uses Sendgrid and SendGrid isn’t too reliable from experience.
When sending newsletters the major thing you need is a way for your users to unsubscribe. I personally recommend using Postmark because they have transactional emails along with broadcasts (marketing).
thank you for the reply. will check it out
Had a lot of trouble with this as well. This ended up working for me: Finally figured out a perfect marketing and transactional email setup
