Bubble does not load <script> although works in empty index.html
Hello! The issue I have is that I am unable to render a chatbot via a Bubble page. It is a one liner script that loads a bundle to display the chatbot. When I insert this line into an empty index.html page in plain code (outside Bubble), it works like a charm.
However, it does not seem to work on Bubble. I have tried both through a HTML element and via the page HTML header, but none work.
Here is how the one liner looks like:
<script src="https://...[mydomain].../bundle.js?id=1694018478971x385571189599764500"></script>
Can you please fix the issue?
Yeah, well, there’s nothing to worry about timing when using an empty index file. Here there is a million things working in required sequences. I bet you’re referring to an ID in your script that doesn’t exist yet when the code is being run. You’re going to want to leverage a load event listener on a specific element, so that the code runs at the proper time.
Also, you mention your domain, and if that’s a local server or something please check for CORS issues.
Thanks @jonah.deleseleuc. The ID is already existing prior to running the code - it is meant to load preconfigured items in the chatbot based on this ID.
Will look into CORS issues as next step.
