Bug reports problem
Hi everyone,
I’m stuck with a very basic issue and I can’t move forward.
I have a data type called Commune.
When I try to create a new entry manually in Data → App data, I can type values into fields like name, country, and region, but as soon as I save, all those fields are cleared.
Only system fields remain (Created Date, Modified Date, active yes/no), but no text fields are saved.
This happens even when creating a single entry by hand, not through imports or workflows.
Because of this, dynamic dropdowns searching for Communes return nothing.
I’ve double-checked:
  • Field types (text / yes-no)
  • Privacy rules
  • No workflows touching this data
  • Development database
Has anyone seen Bubble behave like this before, or knows what could cause data fields to clear on save?
Thanks in advance.
Welcome to the Bubble Community! :tada: :confetti_ball:
So you are creating a record in the database from the Bubble database and it is not saving the data? Can you maybe do a short screen recording to show us?
Are the fields you are trying to save Text fields? Or other dataTypes/option sets?
