How can I capitalize only the first letter of the first word of a text element?
Thanks
Hi there, @quidsicurezza… there are multiple ways to do what you described, and here is one of them.
With this suggestion, you are doing a find and replace on the first letter of whatever string you are working with, and you are replacing the first letter with the the same letter as a capital letter.
Hope this helps.
Best…
Mike
Thanks, but with this solution if Input has all the letters uppercase, how could I change it to lowercase? Because I need just the first letter uppercase
Solved! Thanks!!
