I would like to implement a smooth horizontal scrolling that spills offscreen for product recommendations and other stuff (see attached pictures). I was wondering if someone got it to work or if there was a plugin for this.
Pretty straightforward if you use a reusable inside the horizontal scroll group (check out thebdk.com/native) and you’ll see it in action
Make sure to check the responsive tab in the reusable element too
Could you make a demo app or seomthing? I’m kinda interested in this too.
Understand. Thanks for the screenshots, they’ll do.
Hey @gaurav, thanks for the helpful reply. I haven’t messed much with h-scrolling. I’m curious, though, why you stipulated “reusable” element specifically. I just tried it with a plain old image element, and it seemed to work fine. What’s the benefit of a reusable in this context?
Oh that’s irrelevant it should work in other ways. I was just doing it for a reusable inside my app. It should work fine with image etc. as well.
Cheers,
Gaurav
