I want to collapse a group when it’s hidden, this option used to be present in the Layout tab of the new responsive engine but it isn’t visible as of now in my Layout Tab. Any Ideas?
Hi there, @mediscientdevices… the reason you are not seeing the Collapse when hidden checkbox is because the parent’s container type is fixed. If you change the layout of the parent, the collapse checkbox will appear for the group.
Best…
Mike
