As you can see, at the bottom of the Menu I have an item which allows the user to toggle the Menu Bar, so that it only displays the Menu Icon, which would look like this:
These are 2 different reusable objects. I want the user to be able to click on “Show/Hide” at the bottom of the Menu to switch between these reusable objects, which will give the main screen more screen real estate. I cannot for the life of me work out how to swap out the reusable element using Conditions or any Worflow Steps.
I’d really appreciate any insights or ideas, please!
I added a Field to the User Table: “MenuStructure” (yes/no).
I added both Menus to every Page, initially set to “Hidden”.
I included a Conditional State to look up “MenuStructure” for the Current User and, based on yes/no, I Show the appropriate Menu.
The Toggle Switch on the Hide/Show Menu Item runs a Workflow to update the “MenuStructure” in the Current User’s Record, accordingly.
It may not be elegant - and the change has to be manually applied to every Page in my App - but it works!
