Connection is not secure
I am starting to see this message when I navigate to my version-test app:
Is this related to Bubble or my website? I started my domain/website about 9 years ago and it has always had a SSL certificate.
Using an SSL checker just now, my website, my live app, and the dev app all show they are secure with SSL. So why am I receiving this message? I’m using a Chrome browser on a Mac computer.
I’m planning to launch my beta app after the weekend so I’m concerned about users hitting this message. I’ve only started seeing it in the past month or so…
Hey , just saw the same error . What causes it do you have any idea ? . Same here on conditions
The first thing is to check that your SSL is current and has no issues. I’m assuming you are using a custom domain.
If I recall, I just needed to clear my cache and delete cookies and it started to work fine again. There was something that triggered the browser’s security thing even though it was not correct. Honestly, I don’t remember exactly what it was.
But I think I also recall that the issue was only with the version-test app, and not my live app. The live app did not have the same issues.
So if a user reports this and your app’s SSL is fine, suggest clearing the cache and deleting all cookies to see if it clears it up.
While i had the same problem. Even i have checked my site on some ssl checker everything looks fine. It works now after trying to remove cache and cookies.
