I am attempting to create a QR Code with URL-encoded parameters that will be saved as a PNG file. The values are dynamic, so different values for each customer. When I save the QR code to an image file in Bubble it appears to render properly. Example from my Bubble field:
However when I try to attach the QR Code as a Media file to a Twilio text message I get the following error message from Twilio:
Attempt to retrieve media failed.
Here is the URL that is displayed in the Twilio debugger. Truncated for brevity.
It looks like Twilio is pulling in the parameter keys and not the values and I am assuming this is why I am getting this error message. In trying to sort this out I have saved the format as :S3 but that doesn’t seem to have made any difference.
Is there a way to set this up so Twilio will be able to pull in the actual QR code as a PNG file?
