I am using the Stripe Marketplace Express Plugin to run connect.
I need to create a card_ID token from a credit card form.
I have 2 workflows:
- starts on button click and adds all credit card information with “Create Card Token a Stripe Marketplace Token” to this token.
This should trigger the second workflow that should react when a “Stripe Marketplace a Token created” to create a customer and to save the card_id token,
but the fist workflow is not triggering the second one, thats my problem.
The token is also visible on the page (loads on page load).
I also tried to create the card_id token for a credit card with stripe.js 2 with the same result. 2nd worklfow never starting.
Any idea?
