Currency kr displayed in wrong way
Not reeaally a bug, but a design miss or lack of knowledge perhaps.
2 things:
  1. Currency kr is in Bubble displayed before the number, just like $, e.g. $45. However, it should be the opposite.
    “45 kr”
  2. kr is always displayed using lower case letters.
*bump to top
Should be a quick fix I assume. It poses a problem when using currency. Using number as format instead to circumvent also poses a problem. If you define initial content as “[some dynamic data] kr”, the “kr” doesn’t show if the content format is “any number type”.
It might be an idea, if possible, to treat “extra text” always as an added text string excluded from computation. That’s really what it is, specific to the element.
