Current language issue
The current language gets confused when I change the supported languages. It isn’t getting the language from the phone’s settings.
For example when removed Spanish and added it back, now not matter what language my phone is set to, my app is in French. When I remove French and Spanish as supported languages, it goes back to English. When I had French back as supported and my phone is set to English, the app is in French.
Anyone experiencing this issue to? How can I solve to have multi languages?
It seems to work by my side, do you have your setting/language transltion ?
Do you work with app text ?
Behavior summary
** Mobile apps use the device’s primary language rather than a user-defined setting.*
** If the device language matches a supported dialect, that translation is shown.*
** If it matches a base language only, Bubble uses the fallback dialect you’ve defined.*
** If no match is found, the app defaults to its primary language.*
My app primary language is English, it display french in my bubble go app
Yes I do have the translation, it woks fine on the web app for example, I use the app text indeed. I was able to replicate on another phone as well: the language of the phone was in French, but the app was in Spanish
Are you seeing this on Android BubbleGo? We have a new BubbleGo version coming out that should fix a few Android bugs, including one around app text language handling
On ios bubbleGo app + my published app. I actually can’t get BubbleGo nor my app to open on Android
App text bugs have been fixed. If you OTA any existing builds or submit a new version, you’ll get the fix, and the new bubblego versions (1.8.4) that are coming out soon will also incorporate these fixes
That worked now (on ios), thanks!
