Curse word filter help
I am currently trying to build a curse word filter for my app, since it has a publicly available chat system.
I’ve stumbled upon a problem though, and that involves checking the database for curse words. When I say a curse word without any other words around it, it successfully detects it and warns me. But, when I do example: “Test (badword)” it doesn’t warn me.
My workflow for it right now is:
Any help
Try extracting through regex, it avoids that full word limitation.
If the regex returns something (more than zero, like you do currently), then it means it matched a bad word and shouldn’t be sent.
Maybe try this plugin too: https://bubble.io/plugin/purgomalum-profanity-filter-1489443511590x580126777072681000
Hope that helps! :blush:
@j805 www.NoCodeMinute.com
  • One-on-One Tutoring
  • eLearning Hub
  • Video Tutorials
  • No-Code Classes
Thanks for your response!
I tried using the plugin and following the instructions, but I still can’t get it to work. If possible, are you able to spot anything incorrect with what I did? Thanks alot.
I was able to do it by setting up some stuff with api connector, thanks
Glad it worked! :blush:
