Customizing Dialog box of Material design for Tall language script
Hi there!
We own multi language news App, so everything we design has to be designed for multiple languages. We tried customizing Dialog box text for various languages. Customized it & left all the job for System to handle, which defines your font size as per device screen’s resolution & size. There it created an issue, where it was defining different font size for different devices & which was much bigger than the action button font size of dialog box. As per team, the only solution is to define font sizes for every resolution device and change it dynamically.
I would like to understand if there can be a better solution to it. Or if there is anything that we’re missing out.
Thanks in advance!
