I sent this to customer support as well, and may open a bug ticket too.
According to this documentation Data API Privacy Rules - Bubble Docs, if you use an api admin token to connect to the data api, the privacy rules should be ignored. However, I am finding that even using an admin token I can only get data back if my privacy rules allow all logged out users to see all fields.
Two screenshots attached. Both requests used the same auth admin token. Why are the responses different and why am I only getting data when I allow all by default?
First image: allowing default view all fields
Second: default allowing no fields
This is a bug, right?
