Design and visual
I’m trying to make my website look like the design I have using the AI function but each change I ask doesn’t make it look right and I don’t know if I’m using the correct wording. You can’t upload an image of the design, I have to describe it but it’s not coming out how I want. Is it worth investing in a bubble developer to help with this or am I doing something wrong that can be easily rectified myself? (I’m very new to this with no coding experience)
Bubble ai lets you upload an image, they released that feature not long ago.
Have you managed everything or you need some help?
you should ask some agency or skilled developer to do it. because in future you would require them eventually due to securify features which ai cant do, and every ai makes almost same websites designs so your business or for whatever you are making for should have its unique value and its unique design. thats my suggestion to you, if you need any further help happy to share my thoughts and experience.
Thank you all for your advice and messages, I don’t have the funds to hire a developer at the moment so I’m working my way through what I can with the AI function and I’ll try and get as far as I can by myself and then potentially look at help a bit later down the road.
